HumbleChief Posted December 19, 2024 Share Posted December 19, 2024 Not sure what I'm doing wrong but can't seem to get these windows right. Help greatly appreciated. Plan file below. https://www.dropbox.com/scl/fi/4d6xwlyy502y3bby5a78u/window-challenge.plan?rlkey=1vfyhcnpi9kgxnyozzbwv7ye0&dl=0 Link to comment Share on other sites More sharing options...
HumbleChief Posted December 19, 2024 Author Share Posted December 19, 2024 I think I figure it out. I have a second floor in my template plan and didn't delete it during building the model and the windows ended up on that second floor.. Link to comment Share on other sites More sharing options...
JiAngelo Posted December 19, 2024 Share Posted December 19, 2024 Your windows are on the attic level in the gable wall. This is why they show a negative distance. They are being measured from the attic level. IF you select the left trapezoid and mirror copy it using the window itself and not the doors below, it will appear in the right location. And you can mull all three together. And it shows the same negative distance as the others. I tried mirroring it using the door and it appeared inside the door itself, so it mirrored properly but was attached to the first floor. . .Hope this helps. Link to comment Share on other sites More sharing options...
