Jambruins Posted December 3, 2024 Share Posted December 3, 2024 Attached is my plan and a picture with a red line showing where I would like a retaining wall. I am playing around with terrain lines but can't get it to look quite right. Thanks for the help. plan.zip Link to comment Share on other sites More sharing options...
TeaTime Posted December 3, 2024 Share Posted December 3, 2024 Just looking at the picture I'm assuming you're using regions and lines, but not actual terrain breaks or retaining walls. Check out: https://www.chiefarchitect.com/support/article/KB-00646/placing-a-retaining-wall-in-the-terrain.html Link to comment Share on other sites More sharing options...
TeaTime Posted December 3, 2024 Share Posted December 3, 2024 Sure enough. Scooting that elevation line on the right over a little bit and adding a Terrain Break between those lines will create a break in the terrain where you can add a wall or boulders or whatever. Or using a Terrain Retaining Wall instead, you'll get this Link to comment Share on other sites More sharing options...
Jambruins Posted December 3, 2024 Author Share Posted December 3, 2024 perfect, thank you very much Link to comment Share on other sites More sharing options...
