Foundation display difficulty
VirtualDesign
33 minutes ago, VirtualDesign said:
I am trying to figure out how to makeAttatched Photo 1 footing display as shown in picture 2 with the filled in area but I cant figure it out. It displayed correctly in the past but I dont know what I am doing differently or wrong this time. Any insight would be appreciated
see video
And if by chance you want your foundation to look like your top picture, which looks like a mono slab with a concrete stemwall on it, one way to do it would be to change your foundation walls to pony walls with your mono footing layer being the lower wall at 0" height above floor, and your upper wall being your desired stemwall.
Then open up the dbx for your foundation room and put a ceiling height in to however tall you want your stemwall to be. You might have to change the fill style of your wider lower wall to nothing or white, otherwise it will probably change to a concrete fill once you make it a pony wall.
That should get you a cross section that looks like this, depending on what your wall thicknesses etc.,. are.
