winterdd Posted November 14, 2024 Share Posted November 14, 2024 Howdy guys, question on different ceiling heights. In my default settings the first and second levels are set at 9'-0" ceilings. However in the middle wing of the home they want 10' ceilings. Not so much a problem on doing that. However, every time I reopen the file to continue working on the home the 10' section always goes back to 9' and I have had to select the spaces and manually change the settings back under the structure tab. It is getting old very fast. Can you tell me what I am doing wrong? Pic below, the second floor sits directly above the 10' section so you can imagine the floors sink down when the bottom floor ceiling reverts back to 9'. I don't want to keep changing it just to get by. I'd like to learn the correct way. Thanks. Link to comment Share on other sites More sharing options...
GeneDavis Posted November 14, 2024 Share Posted November 14, 2024 For things to work with a built 2-story plan then wanting to raise ceiling of part (or all) of floor 1, edit the rooms of floor 2 to perform the raise, then go to 1 and do what's necessary. Is this the tray ceiling job? Why not post the plan? 1 Link to comment Share on other sites More sharing options...
winterdd Posted November 14, 2024 Author Share Posted November 14, 2024 13 minutes ago, GeneDavis said: For things to work with a built 2-story plan then wanting to raise ceiling of part (or all) of floor 1, edit the rooms of floor 2 to perform the raise, then go to 1 and do what's necessary. Is this the tray ceiling job? Why not post the plan? Thanks Gene, good catch but no this is a seperate similar home. I am going to check into the 2nd floor defaults like you mention. That makes good sense. As far as attaching plan files, what's the easiest way? Link to a cloud server? Link to comment Share on other sites More sharing options...
winterdd Posted November 14, 2024 Author Share Posted November 14, 2024 When I stopped to really think about it, I realized I was working the software against itself. The highlighted portion is the second floor over the bottom. I had the entire rear porch at 9'. When I changed the portion of the rear porch below the second floor to 10' it seemed to save changes throughout. Man, talk about a headache.............we shall see. Link to comment Share on other sites More sharing options...
