DB-Designs Posted October 17, 2024 Share Posted October 17, 2024 Hello Everyone! I am using X16 Premier and I am putting together some renderings for a client. When I generate a camera view, some of the lights show as on and some show as off. I've tried a few things, like deleting the lights and reinstalling them into the plan. I copied the one that shows on. If I generate a rendering from a different angle, sometimes a different light will show as on and the others would show as off. I don't recall having this issue with C.A. versions. Thanks in advance for the help! I've attached an image to show what I'm trying to figure out. Link to comment Share on other sites More sharing options...
GeneDavis Posted October 17, 2024 Share Posted October 17, 2024 Create s lighting set for each camera view? Be aware of maximum lights permissible in each view? Link to comment Share on other sites More sharing options...
judyjudyjudy Posted February 7, 2025 Share Posted February 7, 2025 Did you ever find the solution to this issue. I'm having the same problem. Tried copying like you. Checked the settings...all the same. Lights are on or of f in different views. Link to comment Share on other sites More sharing options...
