John_B Posted yesterday at 12:41 AM Share Posted yesterday at 12:41 AM I've been using Chief for decades with virtuallyZERO foundation issues...I upgraded to X16 and the first foundation that I asked it to build dervived from the MF has bizzare added edges that actually changes the width of the foundation walls (see example, MF is 24' wide but foundation added 4-7/8"!!!). What am I missing in trying to comphrehend this? The monster sized plan is located here Baseline10-6.plan but doesn't have the foundation yet, you can just ask Chief to build it...there will be some errors but I'm working things one at a time. Link to comment Share on other sites More sharing options...
SNestor Posted yesterday at 01:41 AM Share Posted yesterday at 01:41 AM This is due to your setup in your wall definition...you have selected to have the foundation build to the "stucco". If you change this setting to build to main layer (fir framing) all should work well... 1 Link to comment Share on other sites More sharing options...
John_B Posted yesterday at 03:04 AM Author Share Posted yesterday at 03:04 AM Awesome, thanks SNester, you 'da man...I did look at that tab before and it was set correctly except for the particular offending walls du to the added pony wall width lol! That surely fixe it but I still have remnants (see red areas)...any idea how to make thos go away? Link to comment Share on other sites More sharing options...
John_B Posted 22 hours ago Author Share Posted 22 hours ago Hated to bother Chief Tech Support but they came through! Needed to "uncheck" Brick Ledeges of all crazy things! Link to comment Share on other sites More sharing options...
