Roads and Driveways
mcrump
Do you have "auto rebuild terrain" turned off?  If you do have it turned off, you might not see any terrain in a camera view until you rebuild it manually.  And if you do rebuild it manually, it will be out of date any time you make any changes unless you manually rebuild it again.  You should also see a special cursor that looks like hills with trees on it if you have auto rebuild turned off.
If it's not that, then you might want to post your plan.
