twnctyguy Posted October 3, 2024 Share Posted October 3, 2024 Is there a way to calculate square footage EXCLUDING exterior walls? Thanks. Link to comment Share on other sites More sharing options...
DBCooper Posted October 3, 2024 Share Posted October 3, 2024 I don't think you can do that automatically, at least not very easily. I would probably just generate the living area polyline and manually edit it to exclude the exterior walls. You might be able to get it to work automatically by temporarily changing the exterior walls to have a zero thickness wall type or by messing around with the main layer but this might create all kinds of other problems. Here is a tech article about the living area that might help: https://www.chiefarchitect.com/support/article/KB-00424/understanding-how-the-square-footage-or-living-area-is-calculated.html Link to comment Share on other sites More sharing options...
