cbucks Posted September 19 Share Posted September 19 I have a bunch of elevation points from a GNSS RTK receiver in an app called SW Maps. I can export out in various formats KML, GPX, CSV, I believe even auto cad. Is there a way I can generate 1ft contour lines in Chief? If not any other software you would recommend to do this and then try to import and overlay into Chief? Link to comment Share on other sites More sharing options...
AvoyeDesign Posted September 19 Share Posted September 19 Use File>Import>GPS Data to import your GPX file. I've never used this feature so I can't give you any more help than that, but if you get that far and still have issues hopefully someone else can help too. Link to comment Share on other sites More sharing options...
JiAngelo Posted September 19 Share Posted September 19 We import/export Autocad files. Tell chief which layers are elevation data and it creates the contours in perspective view. Link to comment Share on other sites More sharing options...
cbucks Posted September 21 Author Share Posted September 21 On 9/19/2024 at 4:11 PM, JiAngelo said: We import/export Autocad files. Tell chief which layers are elevation data and it creates the contours in perspective view. Thanks do they always send to you in a certain scale? I have a dxf but not sure the scale tried using meters but it was super small changed to miles and can see things but still scale is not correct not sure what the scale is of the dxf Link to comment Share on other sites More sharing options...
JiAngelo Posted September 22 Share Posted September 22 One's we create in field we specify feet during export. One's we receive from 3rd parties are most often in feet, but sometimes in inches. It happens often enough that I verify those at first import. You will need a known distance between two real world points. This could be a road width, sidewalk length, property line boundary, etc... Link to comment Share on other sites More sharing options...
