Amaconstructionco Posted September 11, 2024 Share Posted September 11, 2024 I am building a shower wall using X16 and only have three options for the shower glass. I am following a tutorial for building it and the tutorial shows a list of sub categories while mine only shows 3. Do I have to upgrade to open these options? Link to comment Share on other sites More sharing options...
ACADuser Posted September 11, 2024 Share Posted September 11, 2024 Not sure what you are asking. Open the material tab to select another type of glass. Link to comment Share on other sites More sharing options...
Amaconstructionco Posted September 11, 2024 Author Share Posted September 11, 2024 I am trying to change the height of the glass, so in order to do this it's telling me to add a railing, change size of glass then delete railing. I only have the three options, general-roof-materials. Link to comment Share on other sites More sharing options...
ACADuser Posted September 11, 2024 Share Posted September 11, 2024 Under Newels/Balusters, below Rail Style you can select the rail height Link to comment Share on other sites More sharing options...
Amaconstructionco Posted September 11, 2024 Author Share Posted September 11, 2024 That's the issue I am having, I do not have that selection, my picture is the one that only has the three selections. Link to comment Share on other sites More sharing options...
ACADuser Posted September 11, 2024 Share Posted September 11, 2024 If you have checked Railings / Solid like you show in the picture you posted, the nexit item should look like this. Link to comment Share on other sites More sharing options...
Amaconstructionco Posted September 11, 2024 Author Share Posted September 11, 2024 These are the only options I get when I select the piece of glass to edit it. Link to comment Share on other sites More sharing options...
Renerabbitt Posted September 11, 2024 Share Posted September 11, 2024 On 9/11/2024 at 6:28 PM, Amaconstructionco said: These are the only options I get when I select the piece of glass to edit it. Expand You are in the Chieftalk forums which is specific to the Chief Architect Premiere line of products which is why he is confused. You have your own forum at https://hometalk.chiefarchitect.com/forum/5-qa/?_fromLogin=CA3 Yes you would need to upgrade 1 Link to comment Share on other sites More sharing options...
Amaconstructionco Posted September 11, 2024 Author Share Posted September 11, 2024 Thank you sir! Link to comment Share on other sites More sharing options...
