HannaBuilding Posted March 18, 2014 Share Posted March 18, 2014 I am trying to set up my layout file - I am hoping to be able to have a few layout sheets with the same plan/ floor , but be able to have different dimensions on each! Trying to get all of the measurements I need on one plan is cluttering up my plans - ( I hope this is making sense) Chief X6 - Still Learning! Thanks - HBS Link to comment Share on other sites More sharing options...
Gawdzira Posted March 18, 2014 Share Posted March 18, 2014 You need to create layers unique to each set of dimensions that you want to isolate. Then you need a unique Layerset for each plan you send to layout so you can isolate the layers per drawing sent. Link to comment Share on other sites More sharing options...
DTCBuild Posted March 19, 2014 Share Posted March 19, 2014 This is what Annosets are all about. I have a floorplan set, a setout set, a roof set etc. Each annoset has it's own layers on/off, text styles, dimension styles etc. Call up an annoset and send to layout for each view required. Extremely simple once set up. Hope this helps. Link to comment Share on other sites More sharing options...
