Steve_Nyhof Posted September 6, 2024 Share Posted September 6, 2024 I made this spreadsheet to help me calculate my footing sizes. I am not an engineer, but now I can make my footings more to the size they should be and if an engineer should be required to verify them. I mainly use it for my foundation footers, but also for decks and exterior rooms that are supported by posts and footings. Maybe there is an engineer out there to verify that I have my calculations correct. The blue fields are where you enter your square foot area totals. The Defaults can be changed as they are there for my area. The results at the bottom are for both Square and Cylinder Footings. The thickness is set to 1/3 the size of the square footing. In many cases for residential, footings seldom need to be thicker than 8". Spreadsheet... Roof and Floor Footing Load and Size.xlsx I'm also including my Footings library... Footings.calibz Thank you, Steve 2 2 Link to comment Share on other sites More sharing options...
tundra_dweller Posted September 6, 2024 Share Posted September 6, 2024 Thanks for sharing, looks like it will come in real handy! 1 Link to comment Share on other sites More sharing options...
para-CAD Posted September 8, 2024 Share Posted September 8, 2024 Steve, You are a generous and helpful man. Thank you. I hope I get skilled enough to do likewise in the future. 1 Link to comment Share on other sites More sharing options...
NRST8TRKR Posted October 23, 2024 Share Posted October 23, 2024 Steve, Thank again. Ken 1 Link to comment Share on other sites More sharing options...
