frankiewalshe Posted August 27, 2024 Share Posted August 27, 2024 I don't see my user catalog under my library browser in x16. Where do I find it? Thank you. Link to comment Share on other sites More sharing options...
DBCooper Posted August 27, 2024 Share Posted August 27, 2024 Did you upgrade from X15 or some earlier version? If so, did you migrate your libraries? Link to comment Share on other sites More sharing options...
frankiewalshe Posted August 27, 2024 Author Share Posted August 27, 2024 Yes, I upgraded from x15. I imported my downloaded manufacturer's catalog but how do I import the user's catalog? There is no user catalog under my library browser. I wanted to add a closet that I just built but can't add as I don't see the user catalog dialogue which was usually under the bonus catalog. Link to comment Share on other sites More sharing options...
DBCooper Posted August 27, 2024 Share Posted August 27, 2024 If you installed X16 on the same machine that you had X15, the program should have asked you if you wanted to migrate your user library. If it didn't, or you told it not to, or if you installed on a new machine, you can always manually copy the library over. See if this tech article helps you figure out how: https://www.chiefarchitect.com/support/article/KB-00001/backing-up-chief-architect-content.html#User It also tells you how to transfer other settings like toolbars and templates. Link to comment Share on other sites More sharing options...
JiAngelo Posted August 30, 2024 Share Posted August 30, 2024 In X15 you.can export your user library as a calibz file. Close X15, Open X16 and double click on the calibz file and it will import your user library into X16. I mucked up my X16 installation and discovered this. I've now deleted all extraneous user items that I rarely use and occasionally revisit X15 to copy/paste/add to library any I suddenly need. Link to comment Share on other sites More sharing options...
