Cadwork22 Posted August 22, 2024 Share Posted August 22, 2024 If I wanted to take a small image from the floor plan and make it into a cad file, how would I go about this? Link to comment Share on other sites More sharing options...
BenPalmer Posted August 22, 2024 Share Posted August 22, 2024 Not knowing the end goal, but assuming it's for a 3rd part, a couple options: export the plan to a DWG...this would be the full plan...if want just a portion of it, you or whomever you are sending it to can edit it CAD>CAD detail from view: then edit it to what you want (fence delete, etc), then export that 'cad detail' to a DWG Hope that helps. 1 Link to comment Share on other sites More sharing options...
