Skip_D Posted August 21, 2024 Share Posted August 21, 2024 Hi, More questions on this roof structure ... 1. The ridge for some reason has two extra members that bump up higher than the roof plane?? 2. Why the perpendicular blocking - seems to run a about 10'; I can't figure out why it's there. thanks, Skip Townsend - 5.3 - Copy.zip Link to comment Share on other sites More sharing options...
robdyck Posted August 21, 2024 Share Posted August 21, 2024 It's a lookout, not blocking. Chief is using it's programming to determine the lookout length. That lookout will be shorter if you have an attic wall enclosing the roof space on the attic level. That's not to say that the lookouts will be exactly how you'd like them, but it does help understand how Chief is building the framing. Link to comment Share on other sites More sharing options...
