Cadwork22 Posted August 10, 2024 Share Posted August 10, 2024 Please review the image, I set on their exterior wall option to set a layer for horizontal framing and set the distance at 24" However only one girt is showing. Thanks, Michael Link to comment Share on other sites More sharing options...
glennw Posted August 10, 2024 Share Posted August 10, 2024 It looks like you may have set the Bottom Run Elevation to 24" and the Stud Spacing to something larger than the wall height. With Horizontal Framing, you need to set the Bottom Run Elevation and the Stud Spacing (even though they are not studs) for girt spacing. If that is not the answer, then post a plan. 1 Link to comment Share on other sites More sharing options...
