Horizontal offset of stair railing panel?
ElkRivers
Does anyone know how to move the panel portion of the railing on stairs?  I can manually adjust the horizontal offset for the top and bottom rails, and the newel posts, but haven't found anything that moves the panel (shown in yellow in the plan view).  If anyone has an answer, I'd appreciate it!  Thanks!
image.thumb.png.ad35a681b698e1683019e8c4f4420647.png image.thumb.png.9060c4225b122a0c04534236bcc569d5.png
Instead of trying to offset the top rail, bottom rail, posts, and then the panel, you can just offset the whole railing using the "horizontal offset" on the "rail style".  Then you can use the other settings to fine tune things like if you want a railing to be aligned with one side of the post or whatever.
