ElkRivers Posted August 8, 2024 Share Posted August 8, 2024 Does anyone know how to move the panel portion of the railing on stairs? I can manually adjust the horizontal offset for the top and bottom rails, and the newel posts, but haven't found anything that moves the panel (shown in yellow in the plan view). If anyone has an answer, I'd appreciate it! Thanks! Link to comment Share on other sites More sharing options...
DBCooper Posted August 8, 2024 Share Posted August 8, 2024 Instead of trying to offset the top rail, bottom rail, posts, and then the panel, you can just offset the whole railing using the "horizontal offset" on the "rail style". Then you can use the other settings to fine tune things like if you want a railing to be aligned with one side of the post or whatever. Link to comment Share on other sites More sharing options...
ElkRivers Posted August 9, 2024 Author Share Posted August 9, 2024 Thanks, DB! Works perfectly, and so much simpler than what I was trying to do! Now, if I can just find you and the money you got away with! Link to comment Share on other sites More sharing options...
