westvale Posted August 7, 2024 Share Posted August 7, 2024 Hello everyone, I'm rendering this house for a visual for my clients, not for construction. How do I decrease the space between the house floor and the terrain? Visually, I want to move the terrain up. Link to comment Share on other sites More sharing options...
Solution Kbird1 Posted August 7, 2024 Solution Share Posted August 7, 2024 53 minutes ago, westvale said: I want to move the terrain up. That's the Answer right there..... Click on the grass , which should let you open the Spec. DBX for the Terrain Perimeter, and uncheck Automatic height and adjust the height as needed.... * Note the Text here, Chief wants the Subfloor Height ABOVE the Terrain M. 1 Link to comment Share on other sites More sharing options...
westvale Posted August 7, 2024 Author Share Posted August 7, 2024 20 minutes ago, Kbird1 said: That's the Answer right there..... Click on the grass , which should let you open the Spec. DBX for the Terrain Perimeter, and uncheck Automatic height and adjust the height as needed.... * Note the Text here, Chief wants the Subfloor Height ABOVE the Terrain M. Perfect! Thanks! Link to comment Share on other sites More sharing options...
