Chiefnewell Posted July 29, 2024 Share Posted July 29, 2024 Does anySite Plan 2.planone know how to cut or trim driveway? I have tried to trim radius on site plan and cannot. also the radius does not transfer to layout page. I received some errors because I still had file open. Thanks, Newell Site Plan 2.plan Layout 2 36x24.layout Link to comment Share on other sites More sharing options...
TeaTime Posted July 29, 2024 Share Posted July 29, 2024 I'm not sure what you're asking, or what you mean that it doesn't transfer to the layout. The Layout looks fine to me. So I'll take a stab at this with a hefty scoop of Assumption on the side: looking at the plan all I see is CAD polylines, no driveways or Terrain so I'm guessing you want to flare out these driveway polylines out to the roads following these circles? If so, just pull the driveway polyline out to meet the road, add a break at the top of the circle so it can be pulled half-way into the circle there'll be snaps on the apex of the top and right of the circle so it shouldn't be hard to get the edges centered. Then click the Subtraction tool and click on the circle to remove it from the driveway. Repeat as needed. Layout should be fine. Link to comment Share on other sites More sharing options...
