philhu Posted July 18, 2024 Share Posted July 18, 2024 Experienced users, I am somewhat of a novice CA user. I generated a foundation plan, but I cannot seem to figure out how to get the first floor features such as walls, windows, doors to show up in dotted lines for reference (or I'll call them phantom lines). Referring to the attached picture, the left is my current plan and the right side is what I would like it to look like. Can someone shed some light on this? I also do not see how to add the concrete symbols such as on the right side plan. Thank You, Philip Link to comment Share on other sites More sharing options...
Solution rlackore Posted July 18, 2024 Solution Share Posted July 18, 2024 Perhaps using the Reference Display and a custom Reference Layer Set will work for this situation. Refer to the Reference Manual and search for "Referencing a Floor Plan." Link to comment Share on other sites More sharing options...
dshall Posted July 18, 2024 Share Posted July 18, 2024 1 hour ago, rlackore said: Perhaps using the Reference Display and a custom Reference Layer Set will work for this situation. Refer to the Reference Manual and search for "Referencing a Floor Plan." Robert is correct... not perhaps but absolutely use the ref layer set method. Link to comment Share on other sites More sharing options...
philhu Posted July 18, 2024 Author Share Posted July 18, 2024 Thank you VERY much for your help gentlemen. That worked! Philip Link to comment Share on other sites More sharing options...
