Tiger57 Posted July 12, 2024 Share Posted July 12, 2024 Good morning all! Not sure why I've 2 different outcomes with the ceiling....using the same knee-wall by just dragging it from room to room.....thoughts? Link to comment Share on other sites More sharing options...
DBCooper Posted July 12, 2024 Share Posted July 12, 2024 For this kind of thing, it usually best to attach a plan to your post. There is a limit on how big the file can be so you will probably need to "zip" the plan to make it small enough to attach. You may even need to delete stuff that doesn't have anything to do with the problem as well. Make sure the plan is closed when you try to zip it and attach it otherwise it won't work. Link to comment Share on other sites More sharing options...
