winterdd Posted July 11, 2024 Share Posted July 11, 2024 Guys, I am having a hard time shaping windows. I know how to "match roof shape" but it still does not make them triangular like shown below in red. I want to delete the middle window and have two perfectly symmetrical triangle windows. I think that would look better for this home. Link to comment Share on other sites More sharing options...
javatom Posted July 11, 2024 Share Posted July 11, 2024 Make the window taller then redo the "match roof". Link to comment Share on other sites More sharing options...
winterdd Posted July 11, 2024 Author Share Posted July 11, 2024 On 7/11/2024 at 9:42 PM, javatom said: Make the window taller then redo the "match roof". Expand Already tried that as well as manipulating the height of the window size. Nothing works...... Link to comment Share on other sites More sharing options...
tundra_dweller Posted July 11, 2024 Share Posted July 11, 2024 If you have the Marvin window catalog downloaded in Chief there are triangle windows in there if you search for P3-1 & P3-2. You should be able to adjust the width & height to match your pitch, or the match roof function might work too. @winterdd 1 Link to comment Share on other sites More sharing options...
winterdd Posted July 11, 2024 Author Share Posted July 11, 2024 On 7/11/2024 at 10:08 PM, tundra_dweller said: If you have the Marvin window catalog downloaded in Chief there are triangle windows in there if you search for P3-1 & P3-2. You should be able to adjust the width & height to match your pitch, or the match roof function might work too. @winterdd Expand I got it to work by manually gripping the window and sizing accordingly and then match roof. The circled area has been an issue for years. Link to comment Share on other sites More sharing options...
tundra_dweller Posted July 11, 2024 Share Posted July 11, 2024 Good deal. For future reference I'm pretty sure it is possible to make triangle windows using the shape tab in the window dbx and adjusting the individual corner heights & offsets too. I think the overlapping casing might fix itself if you mull the windows together. 1 Link to comment Share on other sites More sharing options...
