NRST8TRKR Posted July 11, 2024 Share Posted July 11, 2024 Good morning, I finished my mlast plan in X-15 and started a new one in X-16 yesterday. My desktop is an HP Oman i-7 10700 @2.9 Ghz. with two -8 GB Sticks of ram. It ran X-15 with nom problems but yesterday started getting warning about running out of memory and got slow. Question is should I add two more sticks of 8GB or replace with two sticks of 16GB? Thanks and have a great day, Ken Link to comment Share on other sites More sharing options...
Kbird1 Posted July 11, 2024 Share Posted July 11, 2024 It actually may not be the Memory that is the Issue but the size of your OS SSD as it appears it is only 512gb , is it full? being an older machine you might want to consider a new machine before spending too much on that one, but you could try another 2 sticks of 8gb Ram, however make sure you can return it as it's best for all 4 sticks to be identical if possible, so get the number model off the ones you have and see if you can find them still. I believe Hyper X Memory was rebranded Fury by Kingston but you might still find some of the Older sticks. M. Link to comment Share on other sites More sharing options...
Solution NRST8TRKR Posted July 11, 2024 Author Solution Share Posted July 11, 2024 Thanks Mike, This is what I could Find when I had to replace my desktop when Chief made the grafix chang. Correct about the SSd but I have all my files I wok off of on a 2 t SSD drive.. I think I'll just Swap out the 8s for a couple 16s. Thanks for taking time to reply. Hope it isn't as hot where you are as it is here, Ken Link to comment Share on other sites More sharing options...
Kbird1 Posted July 11, 2024 Share Posted July 11, 2024 7 minutes ago, NRST8TRKR said: I think I'll just Swap out the 8s for a couple 16s. Likely the best bet ...... if going new , research your Mobo. and see if you can use faster RAM eg 3000,3200 or 3600. 1TB ( or 2TB) NVME SSDs aren't that expensive now , and it's fairly easy to clone the main Drive to the new one ( Macrium for eg.) , and then use the old one in an enclosure as an external. and yes it mighty hot here too , but supposed to subside by tomorrow finally. M. Link to comment Share on other sites More sharing options...
NRST8TRKR Posted July 11, 2024 Author Share Posted July 11, 2024 Thanks Mick, Link to comment Share on other sites More sharing options...
