doitright Posted June 28, 2024 Share Posted June 28, 2024 This is my first kitchen design and in placing the dishwasher and wall ovens in the correct position the face of appliances is at the back wall so to make it look good in 3d I have to place them outside of cabinets. Attached image shows what i am referring to. Thought on how to correct this? Link to comment Share on other sites More sharing options...
DBCooper Posted June 28, 2024 Share Posted June 28, 2024 If those are from the core libraries, you can put the appliances into the cabinet instead of as free standing symbols. If you place them as free standing symbols, you will need to change the symbol origin to get the 2d and 3d to match. Link to comment Share on other sites More sharing options...
doitright Posted June 28, 2024 Author Share Posted June 28, 2024 They are from the core library. When I place them on the cabinet the 3d image shows them applied to the back wall. as per attached image. Link to comment Share on other sites More sharing options...
DBCooper Posted June 28, 2024 Share Posted June 28, 2024 Either you are doing something wrong or there is something wrong in your plan. When you put the dishwasher in the base cabinet, the label should change from "b24" to something like "dishwasher". I can see both labels in your picture above which I think means your dishwasher is free standing and not actually in the cabinet. Did you get a message saying something about "the symbol you are trying to place is supposed to go into a cabinet"? When you get this message, it means that you are placing it as a free standing symbol which is why the 2d and 3d don't match. If you can't get it to work, you might want to post the plan. Link to comment Share on other sites More sharing options...
doitright Posted June 28, 2024 Author Share Posted June 28, 2024 Got it. I placed the appliances as free standing objects first to work the layout and that was the problem. Thank you for the help Link to comment Share on other sites More sharing options...
KSDesigns Posted July 10, 2024 Share Posted July 10, 2024 If you place an appliance as a freestanding item, which I prefer to do, you can adjust the Origin Offset on the 3D panel to move it when this happens. The Y Position is usually at 24", which is why it appears in front of where you want the item to sit. If you set it to 0" it will be in the right spot. Link to comment Share on other sites More sharing options...
