ValleyGuy Posted June 26, 2024 Share Posted June 26, 2024 I've never went from Beta to Full Release before. I'm currently using the Beta version and want to upgrade to the full release version. Do I just load the current X16 from the locker? Are there any unique steps involved to keep or save anything (files, etc...) from Beta? Thanks, Shayne Link to comment Share on other sites More sharing options...
Renerabbitt Posted June 26, 2024 Share Posted June 26, 2024 1 minute ago, ValleyGuy said: I've never went from Beta to Full Release before. I'm currently using the Beta version and want to upgrade to the full release version. Do I just load the current X16 from the locker? Are there any unique steps involved to keep or save anything (files, etc...) from Beta? Thanks, Shayne update from beta doesn't require a migration so you should be able to install and just run the program again Link to comment Share on other sites More sharing options...
ValleyGuy Posted June 26, 2024 Author Share Posted June 26, 2024 1 minute ago, Renerabbitt said: update from beta doesn't require a migration so you should be able to install and just run the program again Thanks Rene, do I need to remove the X16 Beta first, or just instal and it will rewrite? Link to comment Share on other sites More sharing options...
Renerabbitt Posted June 26, 2024 Share Posted June 26, 2024 1 minute ago, ValleyGuy said: Thanks Rene, do I need to remove the X16 Beta first, or just instal and it will rewrite? install and it will re-write. this is called an in-place update. your files remain intact 1 Link to comment Share on other sites More sharing options...
ValleyGuy Posted June 26, 2024 Author Share Posted June 26, 2024 2 minutes ago, Renerabbitt said: install and it will re-write. this is called an in-place update. your files remain intact Thanks Rene. Link to comment Share on other sites More sharing options...
