Cadwork22 Posted June 26, 2024 Share Posted June 26, 2024 My plans are calling for a curved ceiling, is this something that can be done in Chief? Link to comment Share on other sites More sharing options...
Solution Chopsaw Posted June 26, 2024 Solution Share Posted June 26, 2024 Yes you can curve a ceiling plane or a roof plane that can include a ceiling. Curved Ceiling: Check Curved Ceiling to specify the selected ceiling plane as curved. See Curved Roof Planes. Specify the ceiling plane’s Angle at Eave, Angle at Ridge and Radius to Framing Bottom. These three values are interrelated - when one is changed, the other two adjust accordingly. You may find it helpful to first specify the Radius value, then the Angle values. A flat ceiling plane with a pitch of 0 has angles of 0 at both the ridge and eave, as well as a radius of 0. 1 Link to comment Share on other sites More sharing options...
