Cadwork22 Posted Tuesday at 07:32 PM Share Posted Tuesday at 07:32 PM Plan attached. Trying to select the open below on the left of the second floor, however it won't select??? RichardFloorPlan.plan Link to comment Share on other sites More sharing options...
BenPalmer Posted Tuesday at 07:41 PM Share Posted Tuesday at 07:41 PM There is no room defined there. The very left (gable) wall is currently defined as a 'no definition' 'attic wall'. Change that to a standard wall (uncheck attic wall, no room definition and no locate) and it will create the room definition that you can manipulate further. Hope that helps. Link to comment Share on other sites More sharing options...
Cadwork22 Posted Tuesday at 07:43 PM Author Share Posted Tuesday at 07:43 PM THANKS! Link to comment Share on other sites More sharing options...
