Cadwork22 Posted June 25, 2024 Share Posted June 25, 2024 Plan attached. Trying to select the open below on the left of the second floor, however it won't select??? RichardFloorPlan.plan Link to comment Share on other sites More sharing options...
BenPalmer Posted June 25, 2024 Share Posted June 25, 2024 There is no room defined there. The very left (gable) wall is currently defined as a 'no definition' 'attic wall'. Change that to a standard wall (uncheck attic wall, no room definition and no locate) and it will create the room definition that you can manipulate further. Hope that helps. Link to comment Share on other sites More sharing options...
Cadwork22 Posted June 25, 2024 Author Share Posted June 25, 2024 THANKS! Link to comment Share on other sites More sharing options...
