RSdesignvt Posted June 11, 2024 Share Posted June 11, 2024 Two Questions, First - Can I eliminate the Insulation off my stem wall only? (Need below slab) Second - I have a cellar opening from the garage, and I want to eliminate the step up to step down - If I lower the door height -8" CA doesnt do anything - I need the framing correct first, and then the stairs! Oh, X16 and I will give my system a whirl. RTX 3080 48GB RAM i7 3.8GHZ All that stuff works fine. Not a CPU Guru - I let my engineer son handle that. thx - R Link to comment Share on other sites More sharing options...
GeneDavis Posted June 13, 2024 Share Posted June 13, 2024 Redefine the stairwell "room" to have floor height equal to garage, and keep its spec as "open below." Break the wall where the door goes, make it balloon through floor. 1 Link to comment Share on other sites More sharing options...
MArco13 Posted June 15, 2024 Share Posted June 15, 2024 Hi there! Thank you for sharing Link to comment Share on other sites More sharing options...
