ValleyGuy Posted June 11, 2024 Share Posted June 11, 2024 Are we still not able in X16 to automatically frame a single 1-1/2" ledger board with a double 1-1/2" rim board on the other three sides of a deck, while having a bearing beam specified as the default? Or am I missing a selection box somewhere? Link to comment Share on other sites More sharing options...
Renerabbitt Posted June 25, 2024 Share Posted June 25, 2024 same question Link to comment Share on other sites More sharing options...
ValleyGuy Posted July 12, 2024 Author Share Posted July 12, 2024 On 6/25/2024 at 5:18 PM, Renerabbitt said: same question I found it.... deck framing isn't fully controlled through the room defaults, double rim boards are controlled via the railing. It seems that different size and material for the outside rim board isn't an option yet, nor is there an option for a thin face trim like a composite deck material. These still need to be manually adjusted / made. Not quite there yet, but definitely a great improvement. Link to comment Share on other sites More sharing options...
