Custom Fields Macro Access Format
JLU_Design
Go to solution Solved by Joe_Carrick,
I'm trying to access some data I have stored in an Object Information Custom Field.
I tied searching the help but can't seem to find any Info.
This outputs all the info in all of the custom fields:
%custom_fields{}%
I want one specific custom field data output.
  • Solution
custom_fields["field name"]
is the way to get the data.  Of course you'll need to specify the object in your macro.  Owner would be typical if you want the outpt in the object's label.
