Cadwork22 Posted June 8, 2024 Share Posted June 8, 2024 See attached I need a garage door with windows in each of the square windows in the door. Or...is there a door in the catalog primarily glass? Link to comment Share on other sites More sharing options...
Cadwork22 Posted June 8, 2024 Author Share Posted June 8, 2024 How can I construct the supports to the porch roof? Thanks in advance! Link to comment Share on other sites More sharing options...
JiAngelo Posted June 8, 2024 Share Posted June 8, 2024 Clopay has a door that's all glass panels 1 Link to comment Share on other sites More sharing options...
JiAngelo Posted June 8, 2024 Share Posted June 8, 2024 The easiest way is to place an enlarged corbel (library) then raise it so the top frame is inside the roof and move it so the side frame is inside the wall. 1 Link to comment Share on other sites More sharing options...
Cadwork22 Posted June 8, 2024 Author Share Posted June 8, 2024 what should I search for in the corbel library Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 8, 2024 Share Posted June 8, 2024 4 hours ago, Cadwork22 said: See attached I need a garage door with windows in each of the square windows in the door. Or...is there a door in the catalog primarily glass? See if this works for you: My New Door.calibz Also, consider checking out my Michael Mailer email subscription service HERE. I normally don't do this, but just a heads up that next weeks email will include a method for making door like this lickety split (as fast as possible for those of you not living in 1800s U.S. :) Link to comment Share on other sites More sharing options...
Solution JiAngelo Posted June 9, 2024 Solution Share Posted June 9, 2024 There's a box awning in the commercial awnings bonus library that I use alot. It looks like your roof but only offers 2 supports and the colors match the flat roof. When I played around with the corbels, resizing them, only the timber corbel worked, but it is awfully big and may not give you the look you desire.. So instead I created a 4"x4"x7' solid, created a side elevation view of the porch and rotated the solid column to 45 degrees. Angled the ends to plumb/level with the porch roof and wall. Then slid it into place under the roof, against the wall. - I colored it osb to contrast with the corbel and the roof - and I left the corbel so that you could see the difference. The solid idea actually works best. I've used the corbels on smaller roofs before and suggested it without thinking it through. My bad 1 Link to comment Share on other sites More sharing options...
Cadwork22 Posted June 9, 2024 Author Share Posted June 9, 2024 Thanks! I ended up using a mini corbel and resized it to fit the porch. Thanks anyway! Link to comment Share on other sites More sharing options...
Alain-Dezii Posted June 10, 2024 Share Posted June 10, 2024 As drawn, they seem a bit hazardous if someone was walk into one of those brackets, or if someone stood up from a seated position. Can you place them on top of the canopy to keep your walking surface clear? Link to comment Share on other sites More sharing options...
