CORNER WINDOW
raltd9245
I am attempting to join two windows to corner windows with two hoppers below. I can join the fixed units without hoppers but when I add hoppers corner windows separarte.
HELP!!!!
The top windows were placed first. Frame at the corner glass is set to "Mitered"
The bottom windows were placed second. Frame on the corner unit has a "Post".
When you say join... you mean placed close together vs. "mull" correct?
Nothing should be joined - aka mulled on the corner units (top to bottom) in case that's what was going on.
Hope this helps. Plan is attached.
All the best.
Untitled 1.plan
