CCarpenter Posted June 2, 2024 Share Posted June 2, 2024 16356 Reitan.planHi All - I created 2 shed dormers on this model. They are back to back and extend to the ridge. They look fine on the exterior but on the interior they don't connect with the ceiling planes. What have I done wrong? Thanks in advance for the help! 16356 Reitan.zip Ext Dormers.pdf Int Dormers.pdf Link to comment Share on other sites More sharing options...
CCarpenter Posted June 3, 2024 Author Share Posted June 3, 2024 Oh sorry! I didn't mean to post 2x's. I thought I had created the query but didn't post it as I didn't see any responses and from my end it looked like maybe it was still in process. In the past others asked for images. I didn't think that sending the extra information would be a problem I created the dormers manually after following the video (1521) posted in the the CA video tutorials Link to comment Share on other sites More sharing options...
Solution robdyck Posted June 3, 2024 Solution Share Posted June 3, 2024 You'll need to make quite a few adjustments: Set the clerestory window elevation reference to 'Absolute' reset the dormer walls to use default top & bottom heights set the dormer walls to 'gable' - NOT knee walls Create an 'Open Below' room (exterior walls > not attic walls, uncheck 'No Room Definition, check connections at each end, make dormer walls one continuous wall) 1 1 Link to comment Share on other sites More sharing options...
CCarpenter Posted June 3, 2024 Author Share Posted June 3, 2024 Perfect, Rob! This worked! Thanks a bunch for your help! 1 Link to comment Share on other sites More sharing options...
robdyck Posted June 4, 2024 Share Posted June 4, 2024 Glad to help! Link to comment Share on other sites More sharing options...
CCarpenter Posted June 6, 2024 Author Share Posted June 6, 2024 16356 Reitan _small.zip Link to comment Share on other sites More sharing options...
