ComputerMaster86 Posted May 22, 2024 Share Posted May 22, 2024 Lower wall type if split by butting roof wont generate. This scenarioalways gets to be a royal big PITA. What's the secret sauce to getting "Lower Wall Type If Split by Butting Roof" to actually work? Roof Project.zipFetching info... Link to comment Share on other sites More sharing options...
TeaTime Posted May 22, 2024 Share Posted May 22, 2024 You've got both Roof Cuts Wall at Bottom AND Lower Wall Type if Split checked. Only one at a time. Why it even lets you do that is beyond me. You'll likely have to manually pull the Hole back, too, but it should automatically reshape itself to look something like this Link to comment Share on other sites More sharing options...
ComputerMaster86 Posted May 23, 2024 Author Share Posted May 23, 2024 I was almost certain I tried that combination sometime earlier in the day and it wasn't working. Now I can't even remember. Anyways, it seems to want to work. Now tomorrow I will be doing something and it will be messed up again. Link to comment Share on other sites More sharing options...
ComputerMaster86 Posted May 23, 2024 Author Share Posted May 23, 2024 On 5/22/2024 at 7:21 PM, TeaTime said: You've got both Roof Cuts Wall at Bottom AND Lower Wall Type if Split checked. Only one at a time. Why it even lets you do that is beyond me. You'll likely have to manually pull the Hole back, too, but it should automatically reshape itself to look something like this Expand Thank you for this piece of information. I will have to try to remember this for similar future scenarios. Link to comment Share on other sites More sharing options...
