FT2design Posted May 22, 2024 Share Posted May 22, 2024 I've never had an issue quite like this before. I did my concept drawings and everything looked great - an associate was working with the drawings afterward to work out beams etc for engineer to approve (who has since looked at this with me and also cannot figure out what happened). Next time I opened the drawing, my ceiling dropped in 3D and cross section although both the room dialogue and the defaults remain correct. You can see in the attached cross section I have highlighted that my ceiling is physically dropped to 84". My Perspective PRIOR image is what it is supposed to look like. The Perspective NOW image shows that the ceiling has dropped and covers up the inner soffit of my ceiling design. This displays consistently throughout the entire foundation level at the 84" height. I've zipped my drawing file and attached it along with dialog box screen shots if anyone is able to tell what has gone wrong. This is the foundation level 0 where I am experiencing the issue I can work around it to communicate my intention on my site drawings, but more importantly I want to know what is wrong so I don't run into it again. Thanks in advance for any investigative assistance! Proposed File Zip.zip Link to comment Share on other sites More sharing options...
FT2design Posted May 22, 2024 Author Share Posted May 22, 2024 My signature was not updated - I am in fact using X15 Link to comment Share on other sites More sharing options...
Solution Alaskan_Son Posted May 22, 2024 Solution Share Posted May 22, 2024 Default Settings>Floors & Rooms>Floor/Ceiling Platform>Floor Structure Uncheck "Framing" for your plywood layer. That setting, coupled with the joist direction lines is causing an extra structural layer to generate and push your ceiling down. Link to comment Share on other sites More sharing options...
FT2design Posted May 23, 2024 Author Share Posted May 23, 2024 23 hours ago, Alaskan_Son said: Default Settings>Floors & Rooms>Floor/Ceiling Platform>Floor Structure Uncheck "Framing" for your plywood layer. That setting, coupled with the joist direction lines is causing an extra structural layer to generate and push your ceiling down. Thank you Michael! I'll fix that right up... Link to comment Share on other sites More sharing options...
FT2design Posted May 23, 2024 Author Share Posted May 23, 2024 6 minutes ago, FT2design said: Thank you Michael! I'll fix that right up... Amazing - that did the trick - thanks again for your clear direction for where to find that. 1 Link to comment Share on other sites More sharing options...
