ChicByDesign Posted May 22, 2024 Share Posted May 22, 2024 I created an annex (right-hand building) to add on a plot of land of an abandoned warehouse conversion in London. It's an odd shaped warehouse so I wanted to honor the architecture, hence the annex is an odd shape (warehouse flipped on its side). I have since determined that I need to rotate the annex to be perpendicular (90 degrees) to the warehouse. I'm hoping there's a way to copy the annex (all floors) and paste into a new plan in the new orientation, otherwise I have to redraw everything. Possible?? I'm using Chief X15. Thank you! Link to comment Share on other sites More sharing options...
SHCanada2 Posted May 22, 2024 Share Posted May 22, 2024 edit->edit Area->Edit area (all floors) select, and then rotate although with two buildings, I would be inclined to make one a symbol and then put that in the other's plan. I've never tried it, but there is also the reference plan, which can show both buildings side by side in 3D view Link to comment Share on other sites More sharing options...
