MN_JohnH Posted May 15, 2024 Share Posted May 15, 2024 I can't figure this out, why the floor joists in the entry foyer on this cabin are I-joists? I have had this happen in other plans too and just can't figure it out. I have my defaults changed to 2x8 framing and the room itself I changed to 2x8 framing but nothing changes it when i go to a crass section. What am I missing here? Floor joist issue.plan Link to comment Share on other sites More sharing options...
Garybills Posted May 15, 2024 Share Posted May 15, 2024 @MN_JohnHcheck in the room specification, structure tab, floor structure. Its set for I-Joist.  Link to comment Share on other sites More sharing options...
MN_JohnH Posted May 15, 2024 Author Share Posted May 15, 2024 30 minutes ago, Garybills said: @MN_JohnHcheck in the room specification, structure tab, floor structure. Its set for I-Joist.  I don't understand that. When I open the file and opened that structure i have Lumber in that box. I have been through that many times. I opened it just now and it is still set to lumber but the cross section shows I-joists. Even when I open the plan from the file here that I uploaded, it still shows I have Lumber in that box, not I-joist. Link to comment Share on other sites More sharing options...
Garybills Posted May 15, 2024 Share Posted May 15, 2024 2 minutes ago, MN_JohnH said: I don't understand that. When I open the file and opened that structure i have Lumber in that box. I have been through that many times. I opened it just now and it is still set to lumber but the cross section shows I-joists. Select line 2 fir framing, you actually have the OSB marked framing. 1 Link to comment Share on other sites More sharing options...
MN_JohnH Posted May 15, 2024 Author Share Posted May 15, 2024 5 minutes ago, Garybills said: Select line 2 fir framing, you actually have the OSB marked framing. Well for crying out loud. I feel stupid now. But I had to ask I just wasn't seeing it. Thanks, 1 Link to comment Share on other sites More sharing options...
Garybills Posted May 15, 2024 Share Posted May 15, 2024 I've been there too, it looks so simple after you spend a lot of time trying to figure something out. 2 Link to comment Share on other sites More sharing options...
