winterdd Posted May 13 Share Posted May 13 Hey guys, main floor is 36" above grade and garage is dropped down 36". How can I get my auto wall caps on my foundation stem walls to move down without having to do molding polylines around the garage? Just trying to use CA benefits and cut down on the manual stuff. I hate molding polylines. Link to comment Share on other sites More sharing options...
TeaTime Posted May 13 Share Posted May 13 If you use the Pony Wall setting you can control the height of the wall cap via Elevation / Height Off Floor controls And not that you should need it, but it also changes how wall caps behave, giving them a vertical offset, too. 1 Link to comment Share on other sites More sharing options...
winterdd Posted May 14 Author Share Posted May 14 Thanks, I will give that a try. Link to comment Share on other sites More sharing options...
