decorators3 Posted May 2, 2024 Share Posted May 2, 2024 Hi How do install recessed / pot lights in a shed roof eave?? I've tried installed in plan view but they end up as ground path lights Thanks in advance Levina Link to comment Share on other sites More sharing options...
Renerabbitt Posted May 2, 2024 Share Posted May 2, 2024 36 minutes ago, decorators3 said: Hi How do install recessed / pot lights in a shed roof eave?? I've tried installed in plan view but they end up as ground path lights Thanks in advance Levina past inside and drag outside and you will need to set some options for them to be flush mount if they arent already, or define a shed room Link to comment Share on other sites More sharing options...
decorators3 Posted May 2, 2024 Author Share Posted May 2, 2024 12 minutes ago, Renerabbitt said: past inside and drag outside and you will need to set some options for them to be flush mount if they arent already, or define a shed room Thanks! would never have thought of that.. That's why CT is so vital,, Link to comment Share on other sites More sharing options...
