westvale Posted April 22, 2024 Share Posted April 22, 2024 Hello! Does anyone know how to get this tab pull mounted on the inside of the drawer? Please see image. Link to comment Share on other sites More sharing options...
Solution ericepv Posted April 23, 2024 Solution Share Posted April 23, 2024 Not sure if this is the same hardware you used but this is what I got using a stock pull: Core Catalog / Architectural / Hardware/ Cabinet Hardware / Pulls / Integrated Pulls Once you specify it, check on 'Vertical Position' or 'Horizontal Position', 'Distance from Top' or 'Distance from Edge' - enter 0" or whatever value meets your needs. Click on 'Edit...' if you need to rotate it. Link to comment Share on other sites More sharing options...
westvale Posted April 23, 2024 Author Share Posted April 23, 2024 That works! Thank you! Link to comment Share on other sites More sharing options...
