binkpear Posted April 20, 2024 Share Posted April 20, 2024 I initially built this open air timber frame building and now I wanted to represent an option with exterior walls. The version I sent is the 'as built' representation. I now need to enclose the building with walls and represent a couple of siding choices. I had built this using walls as room divider around the perimeter so I could create the deck floor. I have started to convert the room divider into a real wall (the photo shows one wall that I converted) and I am stumped as to how to get a wall above the lower hip roof to enclose the gable and eave sections of the upper steep pitched roof. This is a one storey building as I had built it, perhaps that is why the walls I try to get into the gable only generate into the 'attic' space of the lower hip? Any help would be greatly appreciated! Brook Timber frame.plan 1 Link to comment Share on other sites More sharing options...
Solution CharlesVolz Posted April 20, 2024 Solution Share Posted April 20, 2024 Yes, just add a second floor. Timber frame1259140725_Brook CV1.zip Sometimes I will add additional floors to control the bottom of the clerestory walls separately from the first floor. So, the clerestory walls will be on the 3rd floor. The 2nd floor would be used for any loft or attic storage above the first floor. Like this: 1 Link to comment Share on other sites More sharing options...
binkpear Posted April 22, 2024 Author Share Posted April 22, 2024 Thanks for your help Charles! It is much appreciated. Link to comment Share on other sites More sharing options...
CharlesVolz Posted April 22, 2024 Share Posted April 22, 2024 You are welcome! Glad to help! Link to comment Share on other sites More sharing options...
