How To Create Furniture-Style Cabinetry?
I am trying to create a vanity that looks something like the one attached
It would be great if I could put a sink into a table, but alas I do not see a way that I can. I often work with furniture-style cabinetry like this, but struggle with creating it- can someone point me in the right direction?
I think you need to make that from scratch using furniture legs, cabinet with top and shelves.
Make the cabinet the size of the upper portion and set at appropriate height.
You may not be able to find the exact style of leg so you may have to use one that is basically the same
and add polyline solid boxes at the appropriate height and so the same for the shelves.
The sink will insert into the cabinet with the top. Select in 3D view and convert to symbol. If you hold on
the fixtures (sink, faucet) you can add them afterwards and just keep the vanity as a cabinet.
  • 3 weeks later...
  • 3 weeks later...
