Ruby Script Item for Calculating Occupancy Load
amddrafting
Morning all... I'm trying to create a macro to calculate the occupancy load of a room by taking the interior square footage of the room and dividing it by the occupancy load for occupancy type.  Using ChatGPT I got the result of this macro that should help me get the result I need but it's not working.  I assume I first have to get rid of the unit text in order to divide by the occupant load I want to divide by.  So this is the code it came up with.  Anyone ruby script people know what is wrong here?  Does this need to be different because it's in CA?  Any help would be appreciated.
source_information = %room.area.internal%
numeric_part = source_information.match(/\d+/)[0]
numeric_value = numeric_part.to_i
result = numeric_value / 20
puts result
I don't typically donate time to troubleshoot or advise on scripting issues on here anymore, but I decided to make a one time exception this morning:
There are all sorts of little problems:
puts result
1.  %room.area.internal% isn't a Ruby accessible object attribute (name:value pair).  It's just a Chief Architect string substitution macro.  If you want to use this macro in a text box placed in the room, the name:value pair you should be using is simply room.internal_area without the percentage signs.
2.  The match method is a Ruby method used to parse a string.  The internal area attribute however is not a string.  Its a Measurement.  If you want to use the match method, you first need to convert the source_information to a string using the .to_s method.
3.  Just an observation, but you may not be getting the results you think.  The .to_i method is converting your results to an integer which is the whole number rounded down.  0.999 would become zero, 559.9 becomes 559, etc.  What's worse though is that because you're diving by another integer (20) the results of your calculation would also become another integer.  So, instead of 559.9/20 = 27.995 you would get an even 27.  This one can be solved by just converting to a float (which contains decimal values) and then rounding the result.  This can be done a number of ways, but one of the easiest would simply be to replace .to_i with .to_f.
4.  puts isn't used in Chief's text macro environment.  It's simply not needed.  If you try to use it, your results will by nil (empty).
So, the corrected macro becomes:
source_information = room.internal_area
numeric_part = source_information.to_s.match(/\d+/)[0]
numeric_value = numeric_part.to_f
result.round
Although the above macro would work, it still has a handful of totally unnecessary code and could be reduced all the way down to:
(room.internal_area.to_f/20).round
  On 4/19/2024 at 3:52 PM, amddrafting said:
Morning
Expand
first off, mike is the man, love it when I get to read through his approach on anything macros...I believe he may still do ruby training so hit him up :)
I would add in some variables in the beginning in case you ever expand your method and maybe some conditions.
# Copyright Rabbitt Design 2024
# Rabbitt Design assumes no liability for the accuracy of the occupancy calculations or
# any consequences arising from the use of this script. Users are responsible for verifying
# the appropriateness of the occupancy loads and ensuring the script functions as intended
# in their specific use case.
#Use by putting a statement in your text box/polyline label/room_label
#%$occupancy="Educational"%
#Occupant Load:%occupancy_load%
# Occupancy Load Constants
# Note: Load values are in square feet per person
OCCUPANCY_LOADS = {
  assembly: 15,    # Areas for public gatherings (e.g., auditoriums, dining areas)
  business: 100,   # Typical office spaces
  educational: 20, # Classrooms and educational facilities
  factory: 50,     # Industrial and manufacturing spaces
  high_hazard: 500,# High hazard areas with minimal occupancy
  institutional: 240, # Hospitals, care facilities
  mercantile: 30,  # Retail and sales floors
  residential: 200,# Living areas in residential settings
  storage: 300,    # Storage areas with limited occupancy
  utility: 500     # Miscellaneous and utility buildings
# Calculate Occupancy based on predefined occupancy type and defined area
def calculate_occupancy(room_area)
  # Normalize occupancy type
  load_factor = OCCUPANCY_LOADS[$occupancy.downcase.to_sym] rescue nil
  if load_factor.nil?
    raise "Occupancy type '#{$occupancy}' is not defined or incorrect."
  end
  # Calculate occupancy
  occupancy = (room_area.to_f / load_factor).round
  occupancy
end
# Conditionally determine the room_area based on whether 'room' is defined
room_area = if defined?(room)
              room.internal_area
            elsif defined?(internal_area)
              internal_area
            else
              area  # Fallback to just 'area' if the other two are not available
            end
# Call the function with room_area, assuming $occupancy is defined elsewhere
final_occupancy = calculate_occupancy(room_area)
final_occupancy  # This line implicitly outputs the result
You could use this in your room label or in a text box or in a polyline label
In either you could need:
For instance. this will set the appropriate variable call
puts result
result.round
Expand
Amazing!  Thank you so much!  This works perfectly.
Now the next step will be taking that result and multiplying it by .2 to get inches required for openable door clearance code requirement.  Any thoughts?  It would be an if / then scenario.
Ultimate goal would be to get the second number in this graph to display required door opening clearance.  Minimum is 32" but if it exceeds 32" then I would want it to show the actual required amount.
Then I'll need a macro that will count width of doors provided (if labeled "egress') in the room
The end goal would be to just have these in the library that I could paste into the room depending on the room type.  But I'd love to take it a step further and only need one object that could be place in any room and pick up the room type and change the calculation as needed based on the room type definition.  (see my post below in response to Rabbit)
OCCUPANCY_LOADS = {
  if load_factor.nil?
  end
  occupancy
end
              room.internal_area
              internal_area
            else
            end
Expand
Wow man, this was my next thought on how I could use "Room Type" and define them in a commercial template as such.  Then if the "Room Type" was "Business", "Assembly", "Educational", etc.  It would automatically update the label and update the occupancy calculation.  Super powerful tool and kicking myself for nothing thinking of this stuff sooner.
Expand
you could take it even further and make it dependent on a suffix in your file name or change by zip code or many other approaches.
ChatGPT will take you so far but also more complex macros chatgpt butchers..still recommend training with Mike :)
  • 2 months later...
OCCUPANCY_LOADS = {
  if load_factor.nil?
  end
  occupancy
end
              room.internal_area
              internal_area
            else
            end
Expand
:o
