AM2184 Posted April 16, 2024 Share Posted April 16, 2024 HI, I would like to create a new materials with this terrazzo tile pic. It's a 90cm X 90 cm tiles. I added it to my library, but for a 28" length walls, it gave me a tile and a part of tile. I would love it to give me just one tile ( in width ) for a wall smaller of its size. Is that possible? Thank you for your help. Link to comment Share on other sites More sharing options...
ericepv Posted April 16, 2024 Share Posted April 16, 2024 Sounds like you need to offset the material a bit so you don't get a line in the middle of your tile. To correct this, use the 'Adjust Material Definition' tool (the rainbow tool). In the 'Texture' tab, use the 'Offset and Angle' section to move the material on the X or Y axis (click on the 'help' button at the bottom for a more detailed explanation of how to do this. You should also take a look at this article: https://www.chiefarchitect.com/support/article/KB-01006/customizing-a-library-material.html Link to comment Share on other sites More sharing options...
AM2184 Posted April 16, 2024 Author Share Posted April 16, 2024 Thank you for your answer. I'll keep you posted. Link to comment Share on other sites More sharing options...
AM2184 Posted April 16, 2024 Author Share Posted April 16, 2024 Can you or someone else can tell me the difference between the scale in pattern and the scale in texture. The scale in pattern is the size of the tile right? what's about the scale in texture? Link to comment Share on other sites More sharing options...
ericepv Posted April 16, 2024 Share Posted April 16, 2024 The 'Pattern' tad allows you to select a pattern which is different from the pattern in your material. For example, if your material is a standard grid and you would like it as a herringbone, select that in the 'Pattern' tab and then click' 'Keep Pattern/Texture in Sync'. Link to comment Share on other sites More sharing options...
AM2184 Posted May 2, 2024 Author Share Posted May 2, 2024 Hi, It's me again, struggling with tiles. If I want to add this tile on the face of this island, how would you do it? It's a 150cm X 90 cm tile. See attachment. I'm also thinking of adding the tiles to the backsplash over the oven. I really don't know how to do it with this tiles format on Chief. Thank you in advance for your help. Link to comment Share on other sites More sharing options...
ericepv Posted May 3, 2024 Share Posted May 3, 2024 I'd use a material region for both. You can then use the 'Define Material' tool (the rainbow one)to adjust the scale. Link to comment Share on other sites More sharing options...
