Diagonal/diamond shaped window
Leckie
Is there a way to create a diamond shaped window?
Perhaps I have not downloaded the appropriate window catalogue.
Or is this something I have to manually draw in a Cad elevation?
Thanks in advance
Is there something I am missing?
Why can I not select "reflect vertically"?
I know it is always something silly that is left checked or unchecked.
Thank you
Thank you Steve,
That worked but had issues with reflect still.... Turns out I had to remove the sills for it to reflect.
Thank you kindly for your advice.
