Dimensions and Door labels
Ed_Orum
This mornings agita is two fold.
1.  How do I stop dimensions from changing size when I zoom in and zoom out?
2.  How do I get labels to show for doors in an elevation view?  The window labels populate, but not the door labels.  Everything checked for the windows is checked for the doors.  The plan file is attached.  Look at either Elevation 1 or Front Elevation
Thanks,
Lane
Apollino Proposed Plan.zip
2. Your door schedule is setup to use the "schedules" layer for the schedule callouts.  Not sure why you set it up that way but you can either turn on the "schedules" layer or set the schedule to "use object label layer" instead so it will use the "doors, labels" layer (except for D11 because you changed it to use the "doors" layer instead and you might have done this for others too?)
1. try going to your preferences and set your minimum display size for dimensions to 0 pixels.  If you are using the system defaults, I think they are set to something like 8 pixels which means your dimensions will always be at least 8 pixels high regardless of how far you zoom out.
