Joe_cul Posted March 26, 2024 Share Posted March 26, 2024 Cross section shows exterior CMU stem wall height 83.5" tall. Room Specification/Structure shows stem wall 57.5" tall and is grayed out. This is a crawl space. The room specification is correct. Don't want to change the height, just want the cross section the 57.5 height. The attached garage is correct and is not grayed out in the Room Specification and shows correctly in the cross sections. Link to comment Share on other sites More sharing options...
Michael_Gia Posted March 26, 2024 Share Posted March 26, 2024 Check the floor elevations in all the rooms in the floor above. If there is even one room with a floor that has been lowered by accident then this will create the chaos you’re experiencing. (I’m guessing since you haven’t attached a plan or image of the problem ). Link to comment Share on other sites More sharing options...
Joe_cul Posted April 9, 2024 Author Share Posted April 9, 2024 I added some more details. Not sure if this will help. Cross section shows 83.5" high with plate. The Room Specification shows the height at 57.5", what I want it to be. Some items are grayed out, "floor above", "SWT to Ceiling" and a few others. The porch off to the side and the Pillers are correct. Don't want to mess things up by changing to many things. Link to comment Share on other sites More sharing options...
