Changing basement from level 0 to level 1?
JWPrendergast
I would first make a backup plan file just in case and then use edit area to move your main floor to level 2 then once that is clear move your basement to level 1.  Not sure it would all work perfectly though so that is the reason for the backup and it may require some cleanup.  Last time I used edit area some items were not selected but it was manageable.
